Profinet comm speed?
On Profinet I am at:
4 VFDS
8 Ai
8AO
54DI
64DO
The rest of the IO (16Di, 16DO, 4AI, 2AO, and 24 TCs) are in the main rack.
So should be no real pain....depending on the VFD demand.
Impressive, thanks for sharing.
What are they used for? I think I have seen something similar where they used it for separating silicon particles (I think) from a cutting lubricant, such that the lubricant could be reused. Or maybe they could reuse the silicon, can't remember :).
Since you are a "boiler guy"...
Here is one that is on pulse fired burners.
8 burners in roof, with circulation fans for low temp.
This is a shot of the survey being done and the furnace is open at about 2000 F degrees.....max temp 2250 F
This design is called a Tilt-UP...when you see it you understand....for loading with a forklift.
Nat
I've been dozens of coordinated drive systems over profinet
With 20-30 drives on the network - generally 10 words of send and receive
You won't have any problems
That is pretty cool, the only time our boiler glow like that is when you bypass safety and drain them, (ask BSS ;) ).
Most of our installations are steam and hot water boilers, we have a few thermal oil boilers out there and a couple of garbage incinerators (for power generation).
My experience with VLANs in the past has been that everything on the VLAN inside of the corresponding subnet should be able to speak to one...
5,992
Hello and HELP!!! I have a Siemens S7-1500 i TIA and I need to communicate with a Vacon 100 over ProfiNet.. But I have no clue how to do it...
1,780
147
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
380
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
689
