PROFINET FC Cable or Ethernet Cable
spandy16
Dec 2012
Germany
58
I have to connect a Siemens IM 151-8 PN/DP CPU interface module with a PC for program loading and device configuration over PROFINET. My question is whether is it possible to connect the CPU module with a normal Ethernet cable with RJ45 connection or do I need a standard PROFINET cable. My application is just lab based and not in an industry.
I use Just a Standard Cat5e Cable for my test Porpose and just configuring.
199
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
427
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
730
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
334
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,981
