programmable relay
um635
Apr 2015
nebraska
hello,
I am new to the forum and new to plc programming.
My experience is more with gears, belts, and pulleys.
I have a machine that feeds a web of paper through it continiously.
The only control I have now is feed speed, and on and off buttons. I want
to be able to specify a feed distance, then have the machine stop for a specified
amount of time, then feed again and stop. Repeating over and over.
Can I accomplish this with an encoder on the drive shaft going to a plc that will then
control some type of programmable relay?
Any feedback would be appreciated.
thanks
Yes you are correct. You will need a shaft encoder to determine the distance traveled.
As for the programmable relay, you will not need one. The PLC will do anything a programmable relay will do. So it would be redundant.
I can already control the speed of the motor. I was looking to have it start and stop based upon a predetermined length.
There are several programmable relays on the market with a display option. Most of them could probably do the tasks needed without using a plc at all. To get a feel for what is available google Easy-Soft, Zelio-Soft, or Omron Zentool. There are other brands available but these have/are free software or Demo's.
Working with this unit for the first time, is there a way to make this unit behave like a safety relay, as in break a PLC output based on inputs...
3,088
Hi Guys I have 440c-cr30-22bbb programmable safety relay. I am trying to connect the 440R-S12R2 through inputs 14 and 15 of the P.S.R. I use them...
1,331
Has anyone here ever used the AB 440C-CR30 programmable safety relay? I'm having a hard time figuring out how to make it perform the following...
20
13,858
Hello All, I have a moeller relay that I am trying to figure out the logic. There is only one input that is "on" all the time. Output Q1 will come...
2,543
I set up a Zelio relay for totalizing supply & return flows for a boiler fuel oil a while back. There's a MODBUS over Ethernet card on the...
8,340
