Programmable safety relay
smelese
Dec 2019
Port Elizabeth
Hi Guys
I have 440c-cr30-22bbb programmable safety relay. I am trying to connect the 440R-S12R2 through inputs 14 and 15 of the P.S.R. I use them as OSSD inputs.But it won't work. What can I do to solve this issue, or is there anything I am doing wrong?
Some terminals are designed to have one specific function. Some terminals can
perform multiple functions; these terminals must be configured in the
application software. Also, Devices, such as light curtains, laser scanners, and solid-state interlocks, having current-sourcing PNP semiconductor outputs (OSSD) have built-in test pulses (or other method of fault detection). These devices are connected directly to the inputs of the CR30 safety relay and do not use a test output. These devices must
have a common reference with the CR30 safety relay.
Working with this unit for the first time, is there a way to make this unit behave like a safety relay, as in break a PLC output based on inputs...
3,085
Has anyone here ever used the AB 440C-CR30 programmable safety relay? I'm having a hard time figuring out how to make it perform the following...
20
13,858
My plant is going through an upgrade, a 3rd party are proposing a PILZ programmable saftey system (not sure of model) which will have comms on...
2,168
Hi everyone, I know this is an old one but we have a d100 in our wrapper , it just stopped working. When the inputs are pressed the corresponding...
242
Hello all, I have an old machine that utilizes two FEAC PC-116-24 controllers used for position monitoring and output to an OMORM CQM1 PLC. I did...
633
