Programming a micrologix 1200
prallen01
Dec 2009
Middleburg FL
I have a customer that has equipment that has AB micrologix 1200 plc installed in it. I am looking for a way to obtain the software for it. I was told that I need RS logix 500 to program this device. I was also told that this software is 1200.00 plus for a copy.Is this true and is there a lower cost version of this software that would work for this application? I dont program a lot of AB equipment so I am trying to reduce the investment involved if possible. I also have a new AB micro touch screen that the customer would like me to be able to edit. Will RS logix work for this or what do I need. Thanks for this great forum.
There is a starter version and also if you will never need to program the SLC there is a Micro version. Both of these are quite less expensive
Ask you distributor about these
9324-RLM0100ENE - RsLogix 500 Micro Starter
9324-RLM0800ENE - RsLogix 500 Micro Developer
Hi, The MicroLogix 1200 has a Com 0 port and a "HMI/programming port". When looking at the PLC, there is a port on the left side and a port on...
1,757
In micrologix1200 I have only one communication channel so that I do not unable to configure the PLC with Modbus rtu slave driver without losing...
4,280
I need some help with a plc I am working on.... I would like to have 4 push buttons send different analog output signals at one output channel...
4,073
Hello, Does anyone know if can use a : TSXCUSB48 + TSXCRJMD2 (Telemecanique Cables, the first one is a USB->RS485 and the second one is a...
2,152
I have an AB Micrologix 1200 unit. I understand I need to purchase a $ 700.00 software package to program this unit. Is there a cheaper software...
13,925
