Programming Allen Bradley SLC 503
rdredge
Oct 2009
oswaka
17
Hi guys,
I need to Programming an Allen Bradley SLC 503. There is a DF1(232)port and a DH485 port. I know that the 232 is usually used for programming, but is it possible toi use the 485 port? If so would anybody have the wiring diagram for both the 232 and the 485 cables?
Hi guys,
Yes you can program thru the DH485 port.
To connect thru the RS232 port you need a null-modem cable. (see pdf below). All you need is pins 2,3 and 5 the other pins are for hand shacking.
For the DH485 port you will need some extra hardware. This depends on weather or not your computer has a real serial port or not. The best device is a 1747-UIC ( USB to DH485 converter)
Again see pdf below for DH485 connections.
Very nice PDF's.. in all my google searches I had not seen those DH485 schematics. thanks for posting.
I'm looking for someone who is more experienced than to bail me out of this mental thought experiment. I am moving away from programmed alarming...
979
Hello guys, I was reading programming manual of Allen Bradley and they mentioned few tips and I want to clear one tip tip: I/O module data...
2,537
We have a trainer set up and I am trying to learn function block programming to reinforce my resume. In ladder I am pretty fast. I double click...
2,078
My company is about to adventure in to servo motion. I have never programmed them and I am just looking in to it. I am just looking for any tips...
12,776
We have used many AB VFDs, once installed, and under 480vc power, are commissioned via appropriate Drive Software, and network connectivity...
4,916
