Programming Canopen on CX9020 Through TwinCat
Sohaib28
Aug 2015
Cottbus
31
Dear Members:
I am new at Twincat PLC System. I am working on a project.
I have connected CX9020 with a PSI-9750 high voltage power supply via CanOpen. I want to control voltage and current through TwinCat on my power supply. Actually I want to change the values from 0-100%.
I have also load PDO’s from corresponding eds file. I can see a lot of TPDO’s and RPDO’s in system manager. Now I don’t know what to do next.
The only thing I am able to do right now is when I clicked on ‘Box 2(Anybus –CC CanOpen’ and clicked on online tab I was able to change my power supply to remote mode by changing the address there. But I am unable to change values of Voltage and Current there i.e Set Voltage value. Set Current Value.
I don’t know which TPDO correspond to which parameter of my power supply and what type of program I have to create in my PLC Control in which I can change the values of Voltage and Current of my Power Supply. I have also attached some images of System Manager.
Please help
Regards
I shall be thankful to you.
Is there anyone here who can help me. I want to know how to find the TPDO's which corresponds to the value of Voltage and Current. Bcz in my list of TPDOS and RPDOS I cannot see the value of voltage and current. But I can see the value when I click on 'Box 2(Anybus –CC CanOpen’ and then on the online tab.
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
117
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
897
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
84
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
480
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
311
