Programming guide for Siemens MOBY-I RFID system
RMA
Sep 2004
North of Hamburg, Germany
2,052
Does anyone know where I can find a detailed guide to programming the Siemens MOBY-I RFID system. Googling turns up all manner of info some useful, most less so, but so far nothing with specific details of exactly how to program the beasts.
What I need to know is the exact sequence in which commands have to be set up (and are necessary) to communicate with the thing.
I need to modify an existing system and have a couple of problems that I can only solve with more detailed knowledge. Trying to work out what's going on in the Siemens control FC - FC45, is proving to be a bit of a nightmare (he says with mild understatement!).
Entry ID 7399766 describes FC44 for Moby + ASM450.
Maybe that is close enough.
You can try and narrow the search by combining it with the ASM type you are using.
edit: Ignore my post. Krk seems to have found the correct manual (how did he do that ?).
Thanks Kevin, Jesper's right, that FC45 manual is exactly what I need. Guess I've got some reading to do over the weekend!
The Moby-I manual I'd already found, but not the FC45 one.
Cheers
Roy
Doing my first program with an encoder ever. SLC 5/03 processor with a 1746-HSCE card. I have a dual channel single-ended 30ppr encoder I'm...
2,074
Hi, I'm writing a program Yokogawa PLC. Due to the, Yokogawa software is not able to do stimulation, thus I'm writing the program using RSLogix...
7,683
Hi everyone, I'll be assigned to write a program for part of a can(like coke) filling line, the depalletizer. This is the first part of the...
20
7,857
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
128
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
122
