proportional valve test
bahman
Nov 2005
esfahan
19
we had a problem with our system that i'll explained to you as followed:
i worked in the tunneling job.our excavation have stoped before yesteday becouse we had a alarm so-called(cutting wheel brake pressure switch)and it shows us its brake engaged and it sence by a proximity switch.for new excavation this alarm should was released.
in accordance with the plc programm.potentiomete wich belong cutter head speed dosnt worked that with its turning we could adjust cutting wheel speed.potentiometer sent its data to plc and plc it sent to analog amplifier(vt 3000) and then it after command used for control of pilot proportional valve .so we checked our system step by step.
1-checking of pressure
2-checking of potetiometer
3-checking of analog amplifier
4-checking of propotional valve magnet by direct 24 v
5-opening of proximity switch
when we open the proximity switch we observed oil around it.it was damaged.now,our client claimed your test for valve wasnt corect becouse plc output was out of service .this during we dont turn the cutterhead.while we claimed cutter head brake has been leakage and couse our proximity switch damaged.so any body could help me which idea is correct? our test for propotional valve was correct or no?
thank you bahman
thank you bahman
we had a problem with our system that i'll explained to you as followed: i worked in the tunneling job.our excavation have stoped before yesteday...
4,543
Anyone ever PWMd the coils of a bang-bang valve? I tried it recently so that I could reduce machine setup-time by eliminating the manual flow...
41
5,172
Anyone have experience w/ this module/application. I have been tasked w/ using this module to control the flow of chemicals w/ a iQ Tesla...
1,454
Hello. I have a proportional valve with two solenoids which is going to be controlled. The datasheet for the valve (attached) specifies a PWM...
1,696
Has anyone on hear ever heard of controlling a proportional hydraulic valve directly from a PLC with a PWM output and SSR, instead of using an...
19
5,387
