ProSoft Null Modem Cable (Cable 15)
Chris Taylor
Feb 2011
Canterbury
257
I have to reprogamme a Prosoft MVI56MCMR and I cant find my programming lead.
Would anyone have the pin out please.. as I can't find the details at ProSoft
RJ45 one end, 9 pin din the other.
many thanks
Have checked one here and it appears to be as below:
1 --> 1
2 --> 2
3 --> 3
4 --> 4
5 --> 5
6 --> 6
7 --> 7
8 --> 8
9 --> N.C.
The shrouds are also linked. I have a bucketful if you want a couple (just PM an address).
Rob
Kidblue's post is the same as cable 14 see pdf
But the manual says cable 15 is a null-modem cable see pdf
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
75
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
106
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
293
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
437
Hi everyone, I’m trying to copy the configuration from one MVI69-MCM to another. I am having no luck establishing serial comms with the device...
89
