Prosoft PLX31 read from another subnet
Topwater
Jan 2012
Ontario
I have a compactlogix that uses a Prosoft PLC31-EIP-MBTCP gateway to gather data from devices we have in our system. The field devices are Modbus TCP and the compactlogix is of course Ethernet/IP.
All the devices sit on a 192.168.1.xx subnet and communicate fine.
I've been asked to gather data from a Modbus server sitting on 192.168.31.66. temporaily.
What I've done is grab a wireless router we have on site, set the LAN IP to 192.168.1.254 and set the WAN IP on the router to 192.168.31.144 (free ip address on that subnet) and connect it to the system. WAN port to the .31.xx subnet and open ports to the .1.xx side. I disabled the wireless broadcast as well.
If I set my Prosoft card gateway to 192.168.1.254 should I be able to read from this Modbus server? At the moment with this setup I can't get it to work. I'm a little dense on the IT/networking side so any help or suggestions would be great.
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
827
Dear all, Can any one share the procedure how to configure Allenbradley PLC as modbus TCP server with DCS through Prosoft PLX31 EIP MBTCP
2,165
Hello, I've recently decide to try using a prosoft gate to bridge handshakes between two of our processors. Reason being is one is profinet and...
1,376
Hi Experts, Sorry as I am new in working with Allen Bradlly platform & Modbus Communication :bawling:. I have a redundant system ( Control Logix...
5,137
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
75
