ProSoft PLX51-DL-232 to Log Data from ControlLogix
Cydog
Feb 2018
Maryland
313
Good Evening ,
I'm looking for ways to log tags from a ControlLogix PLC.
Have any of you used ProSoft PLX51-DL-232 Data Logger ?
It seems easy enough to setup . I imagine you need a laptop with Excel installed and hooked up along with the PLX51-DL-232 to populate the excel spreadsheet ?
Thanks so much in advance ,
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
78
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
111
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
294
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
438
Hi everyone, I’m trying to copy the configuration from one MVI69-MCM to another. I am having no luck establishing serial comms with the device...
89
