Protool Lite / OP3
teh
Supporting Member
Nov 2002
140
Hi Folk,
I have OP3 and Protool Software, But I have never configure it before.
Can someone show me how to setup it and downlown from PC to OP3
Regards
a few questions.
have you used the step7 software before?
Did you integrate protool into S7 when you installed it?
Do you have the download cable?
Yup, i have use s7 before.
how sholud i integrate protool into s7 software?
is OP3 - PC communication cable same with OP17 - PC communication cable?
if not which typr of cable should i need for OP17 to PC?
Regards
Hello teh,
I dont understand what you need, you need the cable for OP3 or OP17?
For OP3 you will need a special cable with a 9pin to RJ45 plug for PC configuration download, but is included when you purchase the OP3.
For OP17 you need a cable with 9 pin to 15pin plug and the pinout is described in the manual.
i dont know the manual reference, but is available in the site.
Hope this help,
Hi Teh,
Fribeiro's right all the neccersary cables usually come supplied with the OP3, I dont think the OP7/17 cable will work.
If you did a standard Install of protool then i think integration is performed as default.
To get you started, create yourself a new project in step 7.
double click MPI and netpro should open from the menu drag&drop or double click "SIMATIC OP" in the menu stations.
Double click the protool icon and protool will open presenting you with a step by step wizard.
Open up "Text based Displays" and select OP3. Click next and enter PLC name,protocol and communication
parameters.
Click next and use a standard project template until you get familar with the software, Click next and then finish.
Heres the link for the manual i mentioned before:
http://www.sea.siemens.com/autogen/docs/hmi/man/Op3_e.pdf
See how you get on and post back on your progress
Regards
Steve
Hi, I want a valve on a TP170B to change color when something happens: green =open; red= closed; red flashing=problem with the valve. The tags...
2,493
Hi, does anybody have experience with protool/lite? I'm doing a small project with a TP170 panel. I want some tanks (vessels) and valves in my...
2,467
Hello Everybody, I'm looking for Protool/Lite version up to 1.01. Is anybody who has this version of Protool, or anybody who know where I can...
3,211
Hi, I have the upgrade CD from Siemens Protool/Lite v5.0 to Protool/lite v6.0. My old v5.0 version was on my old Win 95 pc. The new one need to...
10,785
Hello All, Would anyone know a simple/Quick method of creating "Tags" in Siemens Simatic ProTool/Lite. I seem to be only able to create Tags by...
2,606
