protool lite
ungaro
May 2005
Lokeren
72
Hi, does anybody have experience with protool/lite? I'm doing a small project with a TP170 panel. I want some tanks (vessels) and valves in my screen but Ihave problems alligning everything. Does anyone have some tips because my first impression is that it has a very crappy editor.
There are aligning tools in the menu bar in Protool.
You can select several onscreen objects and force them to allign to the top/left/right/bottom and you can force them to be the same height and/or width.
Which TP170 ?
TP170A has very limited graphics capabilities. I do not know if it can do what you want.
TP170B has more capabilites. I am certain that it can align objects.
Yes it is crappy but Siemens.
If u haven't found yet ; when u right click on screen page
insert-object>symbol library
u can find lots of tanks and valve sysmbol.
But mine is Protool V6.0 i don't know if it is the same in lite
Thanks. It has alligning tools indeed but i want to allign horizontally and center, but it has only a vertical and center function. I want to allign a line (the pipe) under a tank. I'm using a TP170B panel. Can I rotate ?
Hi, I want a valve on a TP170B to change color when something happens: green =open; red= closed; red flashing=problem with the valve. The tags...
2,493
Hi Folk, I have OP3 and Protool Software, But I have never configure it before. Can someone show me how to setup it and downlown from PC to OP3...
8,426
Hello Everybody, I'm looking for Protool/Lite version up to 1.01. Is anybody who has this version of Protool, or anybody who know where I can...
3,207
Hi, I have the upgrade CD from Siemens Protool/Lite v5.0 to Protool/lite v6.0. My old v5.0 version was on my old Win 95 pc. The new one need to...
10,782
Hello All, Would anyone know a simple/Quick method of creating "Tags" in Siemens Simatic ProTool/Lite. I seem to be only able to create Tags by...
2,606
