Hi, I want a valve on a TP170B to change color when something happens: green =open; red= closed; red flashing=problem with the valve. The tags have to be three different inputs on my plc. Is this possible to make this work. The PLC is Omron
Actually you can specify which state is to be displayed either by "value in tag" or by "bit in tag".You can assign different bits of a byte to one object so I asked if it was possible to assign three different bits directly through the protool software.
What has Windows got to do with it ?????The TP170B is a windows ce device and I have no experience with it so I thought that it would be possible.
