PV+ RAM Error
scottmurphy
Oct 2004
363
I am getting the following error message when attempting to run
my current application.
There is probably insufficent space for opening the runtime project
"\storage card\Rockwell Software\RsViewME\Runtime\project name.mer"
At least 41320 kB of RAM is recommended, while only 40904kB of RAM
is available.
Would you like to try and open the file anyway?
I hit yes and the application opens and runs fine, but I would like to know how to resolve this, if at all. Currently, the runtime app is 3.2mb, how can I determine the what the limit should be, or in this case, correct the issue?
Do images from the graphics library add to memory consumption?
Yes - delete any unused images. My guess would be that after you've done that your problem will go away. Bitmaps consume huge amounts of memory.
I thought as much, I have deleted any bitmaps that are not being used, but there are also images from the graphics library, motors 7 pipes mainly, are these quite taxing also?
Shouldn't be too bad but I would get into the habit of deleting anything that isn't used in the project. It takes a few minutes but it will save you in the long run.
Do you have multiple applications stored on the Panelview plus? I know that when we make changes we generally change the filename and end up having to delete to old one explicity to ensure we don't run out of ram.
Have already encountered this, and do exactly what you have done. Currently, I am downloading to the CF card, selecting 'run on startup', seems like the problem has gone away??
Did a check today on the RAM usage, got the following readings:
RunTime = 19200 kb
Usage = 27912 kb
Avail = 4388 kb
Am I nearing my capacity, can I get extra RAM to increase?
Another question, how can I assign a maximum value to a numeric input function?? I have a popup configured, but cannot change the min/max input values at runtime? I have the popup configured for my max range, in this case 0-25000, but I'm thinking that if the tag limit is 150, and 200 is set, only 150 will be written to the PLC?
If this is the case, then no drama, just a visual thing really.
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,341
Hello, I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when...
1,107
Hello Friends I Have a FX3G CPU and I am modifyind the program to add new models. I have tried to add several rungs but an error appears: The...
1,170
Hi, I have a SLC 5/04 processor, model 1747-L541 that had the backup battery fail a few weeks ago because we didn't see the BAT light on it in...
4,810
I have created the following program in gxworks2. I don't understand why it won't read in the analog value. Sometimes it displays the value but...
1,861
