PV & SLC5/05 Pass-Thru Help
jkerekes
Aug 2007
NJ
2,363
I have some old customer equipment. A PanelView 900 color (2711-T10C9) which has a DH485 Sub D connector communicating with a SLC 5/05 via its serial port. I need to upload/download a program modification to the PV. I don't have an old PIC unit or a USB -> DH485 adapter. An old ATA memory card would work if I had one and a computer with a PCMCIA slot.
That is why I was wondering if I could use the pass-thru feature to communicate to the PV through the SLC via Ethernet and then from the SLC to the PV using DH485. It's been a long time since I tried this. What is the setups to do this? Thanks.
Here you go John...
17573 - SLC 5/05: Ethernet pass-thru DH485/DF1 setup
Access Level: TechConnect
I actually have one system here with a master SLC 5/05 cabled back to the office over Ethernet. The 5/05 bridge is configured to browse a DH-485 network on Channel 0. There are 16 SLC 5/03 DH-485 nodes and 1 PanelView 1000, all of which I can see and access. Works very well.
Regards,
George
I did see that TN. Wasn't sure if it applied to doing uploads/downloads to a PV. Mostly discussed MSG instructions. Let me take another look at it. Thanks.
Yep I can upload/download the PanelView 1000 no problems.
From the Technote (at the top)...
"Note: The pass-thru routing table in the SLC 5/05 must contain the IP address of the computer, this is required to see the PanelView terminal with RSWHO and to upload or download to the PanelView terminal."
G.
George:
Thanks! Got it working. Had the Status bits in the SLC set wrong. Thanks again!
Hello Everyone. PV300: 2711-K3A5L1 I'm trying to do a pass thru on a SLC 5/03 CPU. I have the cpu online on CH1 DH-485. The PV300 terminal is...
2,259
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,558
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,273
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
639
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
926
