PV1200 RIO to PV Plus 1000 RIO conversion
wa5yom
Sep 2003
Ardmore, Oklahoma
138
I have an old PV1200 RIO connected to a PLC5.
I am converting the PV1200 RIO to a PanelView Plus 1000 RIO with the latest firmware.
First, I converted the PV1200 file to a PV1400E.
I imported the PV1400E to FactoryTalkView and created a new project.
I have already configured RSLinx Enterprise with a shortcut to the PVRIO.
As part of the PV conversion process, TAGS and Allases's were automatically created. The Tags appear to point to the Aliases's. I am not sure how the Aliases's are pointing to the Block transfers.
How do I know that the Aliases's are configured correctly?
Thanks,
Tim
Eeewww.....
Went through a similar experience, it was a nightmare....
We ended up mapping out all data in each transfer to the tags in the Panelview...I will never do a this conversion again, the amount of time we spent converting versus completely re-writing was staggering. Lost boat loads of money on that project.
It's tedious, but you'll have to go through it all to make sure the conversation put it in the right spot. Also, not all graphics can be converted, you may have some graphics that don't work correctly that you'll have to re-do.
Sorry I don't have much useful info to give you ;)
so after a previous thread about the panelview 1200. I figured everything out that I needed to get working with it. I've got the RIO discrete...
1,585
I need to down load our panel view 1200+ and have never done it before. What soft ware do I need? We have panel builder 32 but I have never used...
1,875
When I converted the PV1200 to ME for a PV+, Most of the addresses I can go in and change to the appropriate block transfer. But with the binary...
1,814
I have been browsing old posts of 1200 problems and found most of my answers. But if I am not mistaken didn't there use to be a comprehensive...
1,562
We are working on a project, converting PV1200 into RSViewME on RIO. For example if PV1200 is using B3:0/0 as Push_Button_1, can the RSViewME...
3,456
