PV800 Serial Comm with Micrologix1400
Abdul03
Jun 2012
England
77
Hi Friends,
I am trying to connect MLX1400 over RS232 serial communication with PV800. I am not sure where I am going wrong, the PV800 doesn't talk to MLX1400 PLC.
I have attached configuration details for reference, if any one could be able to help me out with this, that would be really appreciated.
Cheers!
That looks like a straight thru cable. I don't believe that will work. The ML1400 manual specifies 1761-CBL-PM02, but that's for port zero.
I think you need a null modem cable. Page 63 of the manual.
As the title says, I'm using CCW with a PV800 (and Micro850). I've made a scheduler in which a user can choose a month, day (1-31), hour (0-23)...
520
Scenario: This is for a system that has a PV800 user interface (connected to a Micro850 PLC) programmed with CCW. There are various control...
550
Hi All I have a Panelview 800 HMI hooked up to a Micrologix 1400 controller. I have communication and have the screen set up with some...
932
I have a USB port RFID Scanner I am using for badging users into certain access levels in an HMI. I know that I could create a 'login' button that...
613
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
620
