zmanvortex
Hi all, I am sending a PWM signal from an AutomationDirect Counter Module to a hydraulic Proportional Valve. The valve coil pulls 1.2 amps at 24 Volts. My plc module can run 1 amp max. I put a 1 amp fuse in series with the signal to protect the module.
It all worked fine when I first fired it up. I never had to go above 50% on the duty cycle and set the run frequency to 200hz, which the valve manufacturer recommended.
After running the process a few times it seemed like the card was current limiting, apparently after the valve coil warmed up enough to pull more amperage. If I paused the process for a couple of minutes it would work fine for a while until the coil warmed up again.
Our mechanical engineer ordered the valve and it is too big for the flow that we need, but I am supposed to make this valve work.
I am thinking of getting a low cost PWM amplifier. Could anyone recommend one or a different solution without changing the plc module or valve.
