jspann7
Hi everyone,
I been searching through the forums and have not been able to find what I’m looking for.
I have a hydraulic proportional flow control valve which requires 12 VDC, 0.2 to 2.2 amps to operate.
I have a Micrologix 1400 B series which I want to use to control the flow of the hydraulic fluid by the flow control valve.
The applications engineer I was talking to told me I need a proportional driver to control the valve because the PLC is either 0-10V or 0-20 mA (not variable 12 VDC). I hence have an analogue module for the PLC so I can control the flow control valve.
My main issue is how the PLC connects to the proportional driver. I understand the solenoid in the flow valve is controlled by the current flowing through it, but the diagram of the proportional driver shows a DC power supply (power +, power -), a reference and another voltage which looks like it varies a 10k pot (potentiometer?).
I know the proportional driver is a PWM unit, so this must have something to do with it.
I have contacted the manufacturer for some information but have not received a reply.
I have attached documentation proportional driver. View attachment Proportion controller.pdf
The valve (p/n: EPFD-16-N-10-0-M-00) information can be found at: http://www.commandcontrols.com/40905/Products/Proportional-Valves/index.aspx
Please note that I am an undergraduate MECHANICAL engineer so am encountering a steep learning curve with this project.
If any one could shed some light as to how the proportional driver is wired up and therefore controlled by the PLC, I would very be appreciative.
Thanks,
Joel
Thanks,
Joel
