Quantum - Modbus plus pinouts
Marcell
Nov 2003
Benoni
17
Some idiot cut the connector off my modbus + drop cable.....the end that goes onto the CPU (140-11302). Now I'm sitting with a 4 wires, Blue/White and Orange/White pairs. What is the pinouts on the 9 pin D-type and should there be a terminating resistor and if so, what Ohms.
From your cable description, I'll assume it's a 990NAD211xx drop cable from a MB+ tap in which case the connection will be:
Connector '1' = Pin 2 = Blue & orange cores
Connector '2' = Pin 1 = Screen
Connector '3' = Pin 3 = White cores
The terminating resistors are connected via jumpers in the MB+ tap
If this isn't the drop cable from a tap, post some more details on the network architecture.....
Now it is more confusing
:confused:
Thank you krk. I received a fax from Schneider SA a couple minutes ago. They have it as:
I apologise for the confusion Marcell, I mixed up the standard MB+ IDC connector terminal numbers with the pin numbers....
I have corrected it now....as you can see Schneider are correct (of course)
I'm trying to resurrect an older machine from around 2005 that uses a 140CPU43412A. The goal is to retrieve the existing program so that it can be...
3,476
hello all, I need help with modbus communication and this is my first time programing the modbus communication in schneider, i have to comunicate...
4,980
Hi everyone! I'm working on a project where I need to communicate a Quantum with a RX3i PAC. The only available driver on the Unity Pro v2.1 (used...
2,946
Hi - I am not familiar with Schneider PLCs at all, but have a question about a a Quantum 140 CPU3110 10 Unity Controller. It has "modbus" and...
3,131
I am having issues getting a Micrologix 1400 to grab a tag from a quantum PLC. I have the message instruction setup correctly I believe but I...
3,190
