Question about testing inputs w/o prog
Scorch Draken
May 2016
Houston, Texas
I wanted to make sure before I did this, but is it safe for the input cards to put direct hot to the input points, instead of just going through a switch. I was thinking, that in theory, even going through a switch, it is straight from the hot, but I want to make sure I am right.
I have to do this to test them, because I have no access to a software to make a test program for a PLC-5.
Thank you, this is very useful for me to know. One more thing, do I have to run the power to them from a second power supply at the input power rating?
Sorry, this sounds like gibberish now that I read it.
What I am asking, do I need a power supply apart from the PLC-5's power supply to put the power to the input points?
Example: A 24VDC power supply to run to the points of a 24VDC fast switching input module and the common of it.
In the final installation it will always be recommended to use a separate power supply for your PLC I/O, but in a test environment it will be OK.
I recommend testing all inputs and all outputs with no program in the processor. Or at least with the CPU in "STOP" mode and NOT running a program.
There is no better/safer way to verify wiring.
For the OP, testing outputs is not possible in Rockwell PLCs without some kind of program. But a program can consist of no logic, just a h/w configuration that is correct. Then place the PLC in run and force I/O with the programming software.
I have a BTEC assignment that requires me to answer the following question: Relating to PLC programming standards and/or commercial products...
2,636
I tried searching for answers on here for some time and the results didn't work for what I was looking for. Apology ahead of time if there is an...
3,698
Recently I took a test for a tech position. There is one question to which I feel I could have answered better. I am taking a poll here to see how...
19
16,544
E
I am new in the field so bare with me please. I just programmed this PLC controlling this machine. I want to test my process to see if it works...
38
12,207
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
64
