Question about using a PLC PID through ethernet?
Ivan B.
Jun 2009
California
Would using a PLC PID to control a motor of a loss in weight device where the motor is controlled through a Modbus or ethernet connection be a good application? The weighing scale would also be communicating to the PLC PID via a Modbus or ethernet connection. I believe that controlling through this type of connection would be slower than analog 4-20ma but would it work effectively at all?
Hi Ivan
A standalone PID controller have a update rate at 100 mSec. I don't think speed is a problem.
Do you do the loss in weight calculation in the PLC or do have a "fixed" device?.
Banker
What type of PLC are you intending of using?
Is this ethernet network going to be solely dedicated to the control of the instrumentation?
Any delay in the Process Variable being read into the PLC or Control Variable reaching destination will add lag to the system. What this means is the control variable will not have the calculated effect on the Process Variable.
Hope this helps
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,026
Hi all, I'm working on a safety circuit and had some question about fusing. Incoming supply - 120V/15A Power supply - PSL-24-060...
590
I'm a novice with Rockwell s/w and a rookie working with virtual machines. I needed a way to support multiple FTView ME versions. so I set up a...
2,969
I am looking to fuse only the commons of my IO cards to protect the plc. Each input point is rated at 6.5 mA with a total of four points, in...
2,756
I operate a distillation column for Argon gas. It has a pressure controlling valve that cools a condenser at the top of the column with nitrogen...
2,272
