Question marks on ActiveX heading text/captions/tool tips in FactoryTalk
MMMcLovin
Jan 2017
Ontario
20
Title explains problem. Basically after transferring from one computer to another, the question marks appear. ActiveX is up to date and registered. I have tried importing using gfx and xml, and it yields similar or worse results.
Should note that I do get a similar problem with non ActiveX components, however importing xml and updating the components fixes the problem. Not only was there question marks, but the text has reverted to older text. the screen was duplicated and changed to fit another application. Only with non ActiveX.
Does anybody have any experience with these question marks?
Thanks in advance.
I cant give files unfortunately because of confidentiality reasons.
Are you using more two or more languages on your project? Usually question marks is related to missing strings.
Also check the regional settings and language on both computers.
I recently added several new screens with multistate indicators. While in English they are fine. When I switch to French they turn to question...
410
I have a PanelView 6+ that runs a ME program. Recently, I've had a couple occasions where the HMI graphics has question marks all over the...
1,629
Hi community! Before I installed CCW my RSLinx was working fine, but after it, I cannot connect to some PLC's in the network and all the devices...
1,496
In FactoryTalk when a text string with a tag has an error a bunch of question marks show up. I was wondering if there was a way to display a...
2,083
Hi guys/gals, I'm having a problem finding a solution to my issue so I thought I'd see if anyone here has some experience with it. We are...
2,650
