Question on an Application using counters - New guy
James Lewis
May 2013
Dallas Texas
I am using a Micrologix 1000 and I am attempting to write a program that will allow a label applicator to label 3 boxes on one side, then label the next 3 boxes on the opposite side.
Both Applicators are verified ON. If on, Applicator 1 applies 3 labels. If it faults out during labeling the three boxes, the PLC immediately switches to the opposite Applicator and continues labeling.
If no errors occur, one applicator applies three labels and then switches to the opposite applicator and applies three labels. It continues this process. If both applicators are in error states, an output is sent to the conveyor to shut down.
This is my first application and I am needing a nudge in the right direction. Any help would be appreciated.
I can set the program up such that, the first applicator is online, the prox sensor senses the product and the applicator applies the label while the counter increments by one. Once the counter gets to 4, I would like to switch to the second applicator, verify its on line, using a separate prox sensor - sense a box, apply a label and start a different counter. Once three labels are applied, the process starts all over again after counter 1 has been cleared.
thanks!
James
http://accautomation.ca/the-secret-of-using-counters/
You can think of it this way:
Your maximum count value is 6. If the count is under 3 use the first label applicator. If the count is over 3 use the second label applicator.
If the count is over 3 and the second label applicator is not on then reset the counter.
If the count is under 3 and the first label applicator is not on then move 4 into the counter PV value.
Hope this helps,
Hope this helps,
Thanks a lot Garry. I wasnt looking at it this way. Makes more sense seeing it written down.
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
91
Hello All, I am going to try and lay out my situation as good as I can. Scenario: We have sites in different location across US that's running...
2,953
We have a project including unwinder-rewinder process. We control motors via torque mode. Me and my collegue have different opinion about a thing...
3,378
Dear All, This is my first time using auto transformer in motor system design. From my reading, the sequence of starting auto transformer is...
4,372
Application question on how would you do it. I will have two PF755 CM drives controlling two motors on an overhead chain conveyor. It was...
1,507
