Quick question about Factorytalk ME driver setup
LowRange
Jun 2016
Omaha
52
Hello, I'm stuck on how to configure drivers to connect to SLC 5/01 and have a quick question.
If I am able to connect to an SLC processor through a DH485 to USB (DF-1) cable with a driver of DH485 UIC com port 3 in RSLinx then what would the my driver in Factorytalk RSLinx Enterprise be? All I want to do is test an application.
Would it be the same driver config as what I use to connect to the processor? Unfortunately when I attempt to configure a DH485 driver there is no option for a com port and when I configure a serial DH485 (whatever that is) I only get options of com port 1 or 2.
Or
Would it be serial DF1 com port 3? I have tried all of this and been unsuccessful.
Thank you!
EDIT: The unsuccessful part is "failure to write false to.." when I test the application.
Long story short - You cannot connect to the processor that way using RsLinx Enterprise.
The 1747-UIC convertor isn't supported by RsLinx Enterprise.
You CAN connect the PVP+ to the SLC, but you'll need to configure the right driver on the Remote tab in RSLinx Enterprise. This won't let you browse the processor while in FTViewStudio though, so you'll probably want to DL to a test panelview to get your tag setup working.
Thank you for the answer. A bit of digging on the internet and I discovered that factorytalk can't communicate through DH485 and that it doesn't like my DFI to DH485 converter.
Hello, I am wondering if when reviewing an application if there is a specific function to identify where there might be any links to a particular...
1,429
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,291
So I have a PID loop on an 1756-L61 running V17 software just for background. Also the PID PV is a pressure transmitter and the CV is speed sent...
910
Has anyone come across a 3 turn potentiometer that is panal mounted with either a 22 or 30 mm hole? I have been looking but nothing so far. They...
20
4,772
Hi, I am just learning CCW, finally got connected to a micro820. I'm wondering what the Version number means. The program that was already in the...
1,636
