Quick Question
GE had a 22mm panel mount pot operator in their C2000 series.
This came WITHOUT the pot and allowed you to select the pot resistance you required. It should work with a multi-turn pot.
Part number was P9CZ.
Since this product line has now been bought out by ABB you might try seeing if it is still available.
I like the encoder Idear. No stops to hit. Thanks
The idear of a 22 or 30 mm was to have a factory built unit thinking it would hold up better then a standard pot and vernier dial.
If you look them up they are rated for 30VDC they are just a switch so you an use them on either voltage
I used them because I needed to be able to reset the speed when the motion stopped
On that project they were the speed reference of 2 VFD's to provide steering on a gantry
when the motion was stopped the differential speed was reset to 0
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,246
So I have a PID loop on an 1756-L61 running V17 software just for background. Also the PID PV is a pressure transmitter and the CV is speed sent...
894
Hi, I am just learning CCW, finally got connected to a micro820. I'm wondering what the Version number means. The program that was already in the...
1,622
How do I measure if I am getting a signal out of the plc output? All of the outputs are giving me the same voltage, however I am certain that not...
2,169
When going "Online" with a running Devicenet network using RSNetworx through a 1770-KFD, will all physically connected nodes appear? I was under...
1,613
