Quick Question about pulse outputs
Sevenfins
Sep 2019
Iowa
How do I measure if I am getting a signal out of the plc output? All of the outputs are giving me the same voltage, however I am certain that not all of them work.
I think that you will have to describe the situation better. Is the measured value of the output what you expect? If it is how do determine that an output isn't working?
Okay, so what I am doing here is pulsing an output to a stepper motor. I am using 4 of them. 2 of them work, the other 2 I believe to not be working on their certain outputs due to a surge we had, because they /were/ working, now they are not. The company I work for doesn't have an oscope, that was my first thought.
Do you have a spare input on the PLC that you can use as a high speed input? If so you can program it and check the number of pulses received per second. Then try each output to the input in turn. Or if you can program the outputs to change very slowly then you should be able to see them on a multimeter.
There are smartphone apps that use the audio microphone as a digital oscope probe; the input wiring would needs a voltage divider, but it's a cheap way to see up to a few kHz.
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,258
So I have a PID loop on an 1756-L61 running V17 software just for background. Also the PID PV is a pressure transmitter and the CV is speed sent...
898
Has anyone come across a 3 turn potentiometer that is panal mounted with either a 22 or 30 mm hole? I have been looking but nothing so far. They...
20
4,720
Hi, I am just learning CCW, finally got connected to a micro820. I'm wondering what the Version number means. The program that was already in the...
1,624
When going "Online" with a running Devicenet network using RSNetworx through a 1770-KFD, will all physically connected nodes appear? I was under...
1,613
