Quickpanel Jr to PanelView
dbrsystems
Aug 2007
Knoxville, TN
20
Hello all,
I have a customer that wants me to convert their Quickpanel Jr. to a PanelView. I've never worked with the Quickpanel Jr. but after a little web searching I found the QuickDesigner 3.7 download that has a 4 day trial. I'm planning to use the software to find all the tags and manually recreate the application on the PV. Is this the best way or is there some conversion software on the net somewhere?
The SLC code is undocumented making the task a little more time consuming.
Thanks,
Leo
I just had the same problem, I updated a really old panel from Siemens that was made on Gracis for Windows (software that was descontinuated since 1998) to a TP270 Siemens that I made with WinCC Flex.
And yes, I think that's the best way, although is very time consuming. It also helps a lot to have the PLC program to be revieweing all the tag's addresses in order to avoid problems.
Best luck with the proyect.
Juan
Hello, I have a GE quickpanel panelview. OS Version Windows(R) CE .NetTM v7.00 The manual says to enable VNC goto: Start -> Programs -> System...
2,496
For a 2001 project using TCP Quick Panels, need to upgrade to PanelView Plus HMI's. I have the original HMI project files but do not have...
2,142
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
347
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
668
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,798
