Quickpanel View scripts
Dave Powers
Oct 2003
Vermont
22
I am using a Quickpanel View touchscreen with Windows CE operating system. I would like to have the VBscripts and Viewscripts be able to read/write the Machine Edition variables. These variables are the PLC access var's and the internal var's that can be used for the buttons, pilot lights, etc. I have had limited success doing this. The ToggleDiscrete command works, and I have also used GetByte and SetByte, but I haven't seen a command that I can just turn on/off the ME var's. I have searched GEFanuc but have been unable to find any good documentation on this subject.
Has anyone done this before? Any help would be great.
Thanks,
Dave
that didn't work, but it did lead me to the correct spot in the documentation. I tried many variations and finally tried this one.
Boolean_variable.value = 1
I had to enter the variable name then have ".value" after it. The problem is there are at least 3 different kinds of scripts and I had to weed through the stuff that was not applicable.
Thanks for your help Steve. I will probably be posting more questions before this project is done.
It is different for VBscript. very similar, but as you can see, just enough to be a pain. I was using the VBscript so that I could have a window pop up to warn the operator. I've noticed that there are advantages for both scripts depending on what you are trying to do. I am slowly finding things in the documentation.
Having trouble connecting and uploading from a Quickpanel View to Proficy Quickpanel communcates to PLC no problem Quickpanel IP...
2,464
I need to try to get an upload from a GE Quickpanel View HMI, IC754VSI06STD-KH, model: ES0611. I saw the thread...
2,785
Hi I'm using GE Quickpanel view and we usually opy the project to cf card and transfer it to the new when we have issues. This time, I need to...
3,723
Hello, I was wondering if any of you have came across this issue I am having. I can download to a 12" IC754VSI2CTD-KJ with my old Windows 7 laptop...
1,935
I'm looking to implement some complex recipes within a GE Quickpanel and noticed in the help files that it's possible to use equations within the...
2,234
