QuickPanel View/ VBscript help.
habit04
Mar 2006
odessa, Texas
Hello everybody...
I am new to GE Fanuc equipment and I am building screens for a QuickPanel View STN 6".
I am wanting to use a momentary button that when pressed will turn a bit on then off in the PLC. We will be using a 90-30 PLC in one location and a versa max plc in another. The bit I need to change state will be a internal bit.
At the same time I want the current window to close and go back to the process screen.
Also we we will be communication via ethernet if that matters?
I am using Proficy Machine Edition v5.60
Thanks in advance.
You got a similar response when you posted on the GE Fanuc forum. http://gefanuc.bnsi.net/eforum/showthread.php?t=9602
Those are pretty basic HMI functions. Have you tried the built-in help files in Machine Edition? Most folks here are willing to help, but you need to make an effort.
When you press a momentary button on the HMI, it writes a value of "ON" to the bit in the PLC. When you release the button, the HIM writes the value "OFF" to the bit in the PLC. There are a couple of ways you can get it to switch to a different page. You could write a script that gets called on the change of state of the bit. You could use an object that supports touch action animation and make it open the other panel.
Having trouble connecting and uploading from a Quickpanel View to Proficy Quickpanel communcates to PLC no problem Quickpanel IP...
2,464
I need to try to get an upload from a GE Quickpanel View HMI, IC754VSI06STD-KH, model: ES0611. I saw the thread...
2,786
Hi I'm using GE Quickpanel view and we usually opy the project to cf card and transfer it to the new when we have issues. This time, I need to...
3,728
Hello, I was wondering if any of you have came across this issue I am having. I can download to a 12" IC754VSI2CTD-KJ with my old Windows 7 laptop...
1,938
I'm looking to implement some complex recipes within a GE Quickpanel and noticed in the help files that it's possible to use equations within the...
2,236
