Fastiva Member F Join Date Nov 2016 Location Ontario Posts 5 Oct 31, 2019 #1 Hello All, Looking to see if it is possible to move an image across the screen and back based on tag value? I have a traversing head assembly that I want to visualize rather than a bar graph showing its position. Is this Possible?
Contr_Conn Member Join Date Sep 2003 Location Ohio Posts 2,582 Oct 31, 2019 #2 You can bind X-Position property to a PLC tag and change values there.
Fastiva Member OP F Join Date Nov 2016 Location Ontario Posts 5 Oct 31, 2019 #3 So then, I would have to do the scaling for length of travel in the PLC?
Contr_Conn Member Join Date Sep 2003 Location Ohio Posts 2,582 Oct 31, 2019 #4 You can do scaling in HMI using expression in binding
widelto Member Join Date Jul 2005 Location Barranquilla, Colombia Posts 3,392 Oct 31, 2019 #5 see attached file @Fastiva: Yesterday I was working with this, but with View ME. See attached file, must be almost the same with view SE
Contr_Conn Member Join Date Sep 2003 Location Ohio Posts 2,582 Oct 31, 2019 #6 @widelto: must be almost the same with view SE Click to expand... OP is using View Designer that is not the same as ME or SE.
widelto Member Join Date Jul 2005 Location Barranquilla, Colombia Posts 3,392 Oct 31, 2019 #7 Sorry for the confusion.
Fastiva Member OP F Join Date Nov 2016 Location Ontario Posts 5 Oct 31, 2019 #8 Thanks for the help! Now trying to sort out the right expression...
