RADES-9300 modem
solehm
Jan 2006
ca
I have 2 computers at the site running RsView SE server as a redundant pair. I have a third computer, a laptop, that will be used for remote monitoring. These computers are connected together using a workgroup.
The problem is that when I connect remotely using the RADES modem, I cannot see the other computers. As a result, I cannot start the SE client application. However, I can ping the other computers and I can go online with the PLCs on the network.
When I am at the site, everything works fine. I can see the other computers on the workgroup and I was able to start the SE client application. I use the ethernet port to connect to the network when I am at the site.
What the different between using the ethernet port and the RADES modem?
Thanks in advance.
Hello all, Has anyone tried a more economical alternative to the 9300 RADES (Allen Bradley PLC modem)? Thank you!
2,751
Anyone ever encountered an A-B Ethernet modem that wouldn't answer an incoming phone call? Any suggestions?
2,931
Has anyone experiencing problems with this device? To me it looks like its a plain piece of sh*t and I'm looking for a replacement from another...
3,981
Can someone give me a quick, blow-by-blow description of what needs to be done to connect to a Compact Logix or Control Logix PLC through an Allen...
1,439
Hello All, I have a question about the setup of a 9300-RADES dialout ethernet modem for communications to SCADA system. On one end I have a...
3,203
