Rate display on Red Lion PAXLCR00
irondesk40
Jan 2008
nc
630
Looking at using a Red Lion for rate display and confused on the instructions for programming.
Max speed = 7730 RPM
Distance Per RPM = 10.6 inches
Encoder pulses per rev = 100
Total revs to equal 1 foot = 1.132
Total pulses per foot = 113.2
Parameter values to show feet per minute
RT- DISP = 60
RT-INP = 113.2
LO-UDT = 01.0
HI-UDT = 02.0
If i understand it correctly this is the only parameters you would enter. If anyone has used these, could you verify if i understand it correctly.
I am having difficulty in finding out how to edit the tag update rate for a display in Vantage Point. Currently the display seems to update...
1,546
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
144
I have been looking to this and thought I'd ask for input from others before I take it in a wrong direction. The guy who used to set these up...
406
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
118
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
224
