Read Ethernet/IP Parameters from PowerFlex 40 Drive use Anybus-X-Gateway
Apr 2015
Windhoek
I have a Rockwell Powerflex 40 drive that needs to be controlled using a Koyo PLC that can only do Modbus. The Powerflex 40 drive is connected to a remote HIM and uses the onboard port that can do modbus. The only alternative now is to control via Ethernet/IP using the 22-COMM-E adapter card on the VSD. To do this I am making use of the Anybus-X-Gateway Ethernet/IP Scanner to Modbus RTU Slave device.
I have been able to get the Anybus to communicate according to the LED indicators on the gateway. This was done by adding the connection points and Data sizes into the Scan List configuration of the Anybus as found on p41 of the 22-COMM-E adapter user manual.
The problem is that I get no data back from the drive and further more need to read other parameters such as current, dc bus voltage, etc. Contacting Rockwell and Anybus hasn't resulted in any success. Anybus refers me to the manufacturer and Rockwell indicated that explicit messaging should be used, which isn't possible as far as I am concerned.
Anybody tried this before or have any suggestions or is this plainly not possible.
Hello Teaan,
The Ethernet/IP Scanner does not support explicit messaging. I apologize for the inconvenience.
Thank you for your inquiry.
ControlLogix L8. Has anyone tried or had luck reading the device name of an ethernet module in the I/O tree? I don't know if its possible however...
1,504
We are going to pull 5-10 INT parameters out of 6 soft starts via explicit messaging in logix 5000. It's the only way we can read these over...
2,480
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,818
PLC is ControlLogix 1756-L73 CPU with firmware 28 In the PLC the value for A60[110] is "AT", Style ASCII, Data Type INT. In KEPServerEX I tried...
1,568
Yesterday I was working with an Allen-Bradley Controllogix and a Compactlogix. I was using a MSG instruction to read from the Controllogix via...
1,135
