Read from clock?
DellSuperman
Apr 2011
Singapore
Hi all,
I have a program that i need to have a data pluck out from a counter at an hourly interval & to be displayed at another area.
In total, there will be 24 text boxs to be filled.
Other than using a timer, are there any other alternative for the hourly timer? My worries on using the timer is that when the PLC is turned off, the timings will go wrong.
Thanks in advance.
Some PLCs have internal real-time clocks. Others have modules. If your PLC doesn't have a real time clock or a module you can add to add the feature, you can use an HMI with a built in real time clock to send real time clock data to the PLC.
Thanks Tharon, I will look into that...
Hello I was needing to stop one device and start the second device at a certain time each day, for example 10:00 am each day. I thought the best...
5,231
Hello, I am using a Micro 850 plc with a Panelview 800 for the first time. Programming software apart... For the rest everything is ok. I only...
8,407
can anyone help me about how to use Real-Time Clock to run pump at certain time everyday
4,203
I'm trying to get my HMI's (TP170A) clock to sync with my S7 300 PLCS clock. I've tried using SFC1 in OB1 to read the PLC clock into a DB but its...
7,210
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
152
