I am trying to set up a msg read and write using a controllogix and PLC5.
All the MSG instructions will reside in the CLX. The CLX is on an ethernet network, which also has a ethernet/DH+ gateway (172.18.50.85). The gateway has 2 cards in a 4 slot chassis, slot 0 is ENBT, slot 1 is DHRIO. This gateway is connected to the DH+ network (CH B) which the PLC5 (node 22) is on.
I am having trouble writing out the address string in the MSG block in RSLogix5000. I know i need to go the IP of the gateway, then i get confused. Is it backplane (0), then DHRIO card (1), CH B (2), then the node of the PLC5 (22)? So 172.18.50.85, 0, 1, 2, 22 ?
