Reading speed from Magnetic pickup
If the low speed causing too low of an input for even a signal conditioner, then I agree change to a prox switch.
qwemx
have you made sure that the mag pickup is as close to the teeth as possible <0.2mm, this will increase voltage output significantly. If that fails, use a proximity sensor
Yes we have adjusted the gap and also tried to increase the number of teeths but unable to obtain higher Voltage
Good day All, Forgive me if this isn't a question that fits into the scope of the forum, but I am hopeful someone here my be able to help. I am...
2,041
Hi Guys I've got some application where i need a very high accurate speed measurement for a line and the encoder cann't achieve such accuracy due...
1,713
Hi, I want to know how to read high speed Inputs given to 840D NCU. How one can see status of these on PCU or MMC
1,963
Hello, When I try to read from the PLC, the following error occurs: There is no project name. Failed to read the intelligent function module...
82
349
