g.mccormick Lifetime Supporting Member G Join Date Jul 2012 Location IN Posts 961 Sep 12, 2021 #16 If the low speed causing too low of an input for even a signal conditioner, then I agree change to a prox switch.
qwemx Member OP Q Join Date Jul 2017 Location Earth Posts 195 Sep 13, 2021 #17 The frequency output will be 0 to 2000HZ, it will be less than 2000 HZ
drbitboy Lifetime Supporting Member Join Date Dec 2019 Location Rochester, NY Posts 8,179 Sep 13, 2021 #18 Previous responses by @parky, @pturmel, @kalabdel, @g.mccormick all say use a proximity sensor. https://www.google.com/search?q=+proximity+sensor+2000+hz
Chris Taylor Lifetime Supporting Member Join Date Feb 2011 Location Canterbury Posts 257 Sep 13, 2021 #19 qwemx have you made sure that the mag pickup is as close to the teeth as possible <0.2mm, this will increase voltage output significantly. If that fails, use a proximity sensor
qwemx Member OP Q Join Date Jul 2017 Location Earth Posts 195 Sep 13, 2021 #20 Yes we have adjusted the gap and also tried to increase the number of teeths but unable to obtain higher Voltage
