Recommended Cable For MODBUS via CMM002
TPCTJ
Jun 2012
Minnesota
21
Hello,
I have an RX3i IC695CMM002 communicating with a Varec 8130(Tank Gauging RTU) and the data is in and out sporadically. My team's thought is the 8130, which is taking in the data from 40 tanks, is the bottleneck but we want to make sure it isn't our equipment so we want to get the right/recommended cable in there. As of right now, we have a CAT5 plugged into the CMM module (with pinouts according to GE) and we are wondering if there is a way to get a twisted shielded pair connected to an RJ45 connector...it just doesn't seem to fit right when I try to crimp it.
The thing is, the length from our panel to the 8130 is less than 20'...so I find it hard to believe we would need twisted shielded, but :unsure:
Any suggestions on a cable for this module?
Thank you,
T.J.
Hi, Dose anyone have recommendations for Ethernet cable for site-use with laptop? I usually use regular office cable, but the lock-pin usually...
3,907
It sounds obvious, I know. The cost of good VFD cable for many motors over a modest distance is quite pricey. The manuals say to always use a...
5,626
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,183
Hello all, I have a client that needs to externally control some valves at a small plant, nothing fancy. (for which I just need digital IO)...
3,945
We are going to be using a SIRUS 3RW5545 Soft Start to control a 480V, 150HP fan. Looking for some recommendations for parameters to use with this...
853
