rj061991 Member OP R Join Date May 2014 Location iligan city Posts 75 Jun 9, 2016 #16 oh i see.. so my only option is to use modbus tcp in two master?.. is it ok to use in 150 meters distance? from i/o to hmi?
JHarbin Member J Join Date Sep 2009 Location NC Posts 909 Jun 9, 2016 #17 rj061991 said: oh i see.. so my only option is to use modbus tcp in two master?.. is it ok to use in 150 meters distance? from i/o to hmi? Click to expand... The Ethernet standard is 100 meters max unless you are using fiber. It would probably be cheaper to put a switch somewhere in the middle.
rj061991 Member OP R Join Date May 2014 Location iligan city Posts 75 Jun 9, 2016 #18 JHarbin said: The Ethernet standard is 100 meters max unless you are using fiber. It would probably be cheaper to put a switch somewhere in the middle. Click to expand... what switch?? like a repeater?
JHarbin Member J Join Date Sep 2009 Location NC Posts 909 Jun 10, 2016 #19 rj061991 said: what switch?? like a repeater? Click to expand... Please do an Internet search for Ethernet - cabling and equipment
