Red Lion - Beckhoff tags
steven23
Nov 2015
Ashford
Hello,
Does anyone have experience setting up Crimson 3 to a Beckhoff CX series PLC?
I am trying to set up communications between a Beckhoff CX5010 PLC and a PTV000.
I’ve followed the ‘Beckhoff ADS TCP Controller Information Sheet for Crimson’ to setup the communications. I am using Ethernet. I have setup the driver to be Beckhoff ADS/AMS TCP.
I’ve changed the driver settings to use the AMS NetID and IP addresses of the target PLC.
My question has to do with setting up the data tags. When I setup a flag-tag, I change my source to PLC1 (Beckhoff ADS/AMS TCP protocol) and the ‘Select Address for Beckhoff ADS/AMS TCP’ dialog box appears. I’ve tried typing the address from the TC System Manager I/O-Configuration tab (in this case it’s 3169.2) with the Data Type ‘Bit as Bit’ selected, but it truncates the .2, so then I tried 1796 with the Data Type ‘Byte as Byte’ selected and treated the Data Source as ‘Bit Array Little-Endian’ with no luck, I have also used the PLC address Q0.1 with no luck, the value returns a N/A. What address/element should I type into the element box?
I have a Siemens protocol running on the same unit and all tag values retured are valid.
Thanks for reading!
Does anyone have experience setting up Crimson 3 to a Beckhoff CX series PLC? I am trying to set up communications between a Beckhoff CX1030 PLC...
4,384
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
271
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
283
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
116
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
235
