Red Lion CSDIO14R connected with G315 via CSMSTRV2
amitpanvekar
Jan 2013
London
44
I got CSDIO14R connected with CSMSTRV2. and the CSMSTRV2 connected with G315 using Modbus TCP/IP.
I am receiving all the data into G315 via RS232 Port at G315. I have alarms based on the data received at G315. Now I want to turn on the light connected with CSDIO14R's output. How can I do it ?
Your help is appreciated.
Cheers
Hello,
You would need to create a trigger on the tag you are monitoring. This trigger can be used to set a tag which is mapped to the output of the CSDIO.
Jeremy
Thanks JeremyH,
What I want to achieve is that I have input at DSPSX000 RS232 port. Now I have all the data tags from DSPSX000 into G315 HMI using OPC TCP/IP.
Now based on the specific data tag value I want to turn on the CSDIO14R output e.g. (red is an integer data tag I want CSDIO14R output-1 should be 1 when red=1, please note that red is defined in G315 but I would connect G315 with CSMSTRX usinh NTRON 104TX). Is it possible to do using a programming or is there any other way to do it ?
Help is deeply appreciated.
Cheers
79
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
291
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
301
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
249
