Red Lion Display Scaling.
kn2
Jan 2010
Alberta
I recently was using a Red Lion G3 6in, however I accidentally created everything in a 10in program. Does anyone know of a way to have the Crimson software convert this for you? I ended up re doing everything in a new file.. it was a pain, cause I couldnt just copy and paste from window to window without getting errors that would cause Crimson to shutdown. If anyone knows of an easier way so if it were to ever happen again (although I am paying much better attention now) that would be great!
It would also just be handy if at the last min. your client decides to upgrade to a 10 and you created everything already for a 6.
Just curious.
There is no way to convert to a smaller size. As far as the copy and paste, the location of the item you copy is also copied, so when copying from a 10 to a 6, you need to make sure that the item(s) you copy are in the upper left 320 x 240 of the display.
Regards,
Dan
I'm trying to set up a Red Lion display where the operator can enter a batch number on the screen. However, the batch number will contain a...
2,176
Looking at using a Red Lion for rate display and confused on the instructions for programming. Max speed = 7730 RPM Distance Per RPM = 10.6 inches...
1,328
Good morning everyone, a quick question, I have been trying to get the time to display on the trend viewer in Crimson 3. It doesn't look like its...
2,432
I have not been able to get the elapsed time from a timer in a Siemens Simatic S7-1200 to display correctly on a Red Lion G315 HMI. I have...
18
8,581
Has anybody created images that dynamically change based on inputs. I know how to do bar graphs, but I want to show the steepness of the angle...
3,292
