Happy Holidays Everyone,
I have a Red Lion G09 HMI that I am logging data to the SD card. I should say that it use to log data on the SD card. When I first set it up it over a year ago it was logging just fine. Now it doesn't show anything on the SD card at all.
I had the site supervisor replace the SD card because I thought that maybe the one I put in there was bad. No luck. When I try and format the flash in the Crimson 3 it says that no card is inserted. Same with the old card.
I have updated the firmware several times since it was installed and is now running the latest version. Other than that and adding some screens nothing has really changed.
I had a simular issue with the older G306 model. The CF card was not compatible with the HMI. I ended up ordering CF cards from Red Lion and the problem when away. Could the Graphite series have the same issue?
Anyway any help you can provide would be appreciated.
