Red lion G3 email
Mbeavers34
Jul 2009
mattoon
32
Anybody using the G3 email feature?
I have tried a few things but haven't been able to get it to send me an email.
I'm sure (well pretty sure) it has to be one of my settings but.....which one?
I have mail manager enabled.
I'm connected to the same network as the G3 with my laptop
I can ping the G3 so, I know the ip address is good.
I get the time from a NIST server so, I know I have internet connectivity.
SMTP settings should be correct. (using the same IP, port, username, and password that I use to log on from my laptop.)
I have an alarm tag set up that when it's true it sends an email to contact 1 (my yahoo account).
Also wrote a short script that is activated when the button is pressed.
SendMail(1, "Test Subject Line", "Test Body Text");
Does anybody have a setup for hotmail, yahoo, etc. that they would be willing to share?
Or is there a good way to test my assumptions that everything is correct?
Michael
Have you set up the SMTP sectionon the mail manager. I use this feature a lot but we are on our own mail server here not a Yahoo account.
o_O
Yes, I have it set up. We actually have our own mail server too, but I haven't been able to get it to work with the G3. I created a Gmail account thinking maybe it was something with our email server but even with the Gmail setup I haven't been able to get it to work.
I have had no luck using Gmail or Yahoo to send emails. We use, and have recommended using a 3rd party mail server (AuthSMTP.com) that charges a very fair fee to send emails. Send me a email (dany at redlion.net) and I will give you the settings for our account, so you can give it a try.
Regards,
Dan
Basically Dan suggested using AuthSMTP. Its a third party program for SMTP mail relay and only cost a couple $ per month. Once I got the IP address and port set up in the G3 it worked just fine. For what it's worth I had similar problems getting SMTP to work when setting up a 'PINK' board on a parallax micro-controller. Took a while working with the IS guys to get the right settings and had to send the board back in for a software update. Seems the mail servers are adding more security and more options are needed on the client side.
Michael
I had the same probles... our email server was in AZ and I could not get any help from the IT dapartment there
Hi everyone, I have a Red Lion CR3000 HMI that I am trying to set up to send a email when there are certain alarms. So far I have had no luck...
4,455
Hi Everyone, I'm using a small program to generate emails when certain conditions are met like when a counter exceeds a value. I was hoping that...
2,005
Hi all, I have a customer that wants me to send a email based on a specific event. I have created a trigger that creates a Data File based on...
3,291
Greetings All Need pointing in the right direction. Been a few days, configured G3 email feature with no success. Checked IP addresses or all...
2,580
Trying to send an email of one var. got the email part working but cant seem to get the var embeded in the email. below is my code. can anyone...
3,022
