Red lion G3 + Misubushi Q series IP address Question
nozynoz
May 2013
Bolton
Greetings all
Confused, need help live environment
Have a problem, might be simple or being lined up to be shot.
Newbie in the field, need pointing in the right direction.
Need to change the IP address's on both items.
My problem is that I could just change the IP's through crimson and thats it. "Job well done".
It might work as crimson will change IP address on Mitsubishi PLC, or do I need to change it on PLC ??, using GX developer.
just looking for confirmation.
Many thanks in advance
Greetings all
Crimson will not change the IP address on the PLC.
You *set* the IP address of the Display through Crimson, and you tell the Display (through Crimson) which IP address to look for to find the PLC, but the PLC needs to already be at that address for the Display to find it.
I haven't worked with Mitsubishi, but I assume that would be done through the Programming software - most PLCs are set that way.
Cheers for that.
Thought is was the case.
looks like need to acquire some GX Developer skills.
Much appreciated, thank you
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
73
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
282
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
292
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
126
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
246
