Red Lion G3
Don't laugh at me.
Here is a quick and easy WIDGET example.
A basic stoplight breakdown.
A small Program1 runs On Tick under the Display Pages, Pages selection (No I didn't miss-type Pages twice) Just to make the lights change color.
The Zip has the .cd3
I enjoy doing GoToMeetings to teach Widgets when I have some time. I am going to New Orleans this week for the WorkBoat Show but might be able to do a 1 hour session on Friday. Send me a PM if interested: [email protected]
Joe_WaZoo
Jeff,
Yes I did. That is a nice write up. I think you might be missing the name of the Binding Folder prefix. Looks good.
Joe_WaZoo
I am a rookie what can i say. I leave that blank so I can drag and drop what ever folder I want and as long as it has the correct tags it doesn't matter
Thanks Guys for posting, especially Jeff.
Just to let you know my progress, I have been away on holidays for the last few days, so I hope to get back to this project this week.
I will have to take some time to digest what Jeff has posted.
Cheers
Ian
Hi All,
Just if anyone is following this thread, here is the solution that I have come up with...
To recap on what I was trying to do, I had 30 products that ran down a production line, with about 50 odd variables for each product. I was trying to avoid creating 30 pages (ie one page for each product, with 50 different variable tags on each page).
I found the function SET(Tag, Value).
So from the source page, if I wanted to edit Product 1, I had the following "complex" code tied to a button
Set(Product_Edit.Product_No_Select_For_Edit, 1);GotoPage(Product_Edit);
The code for Product 2 button was then
Set(Product_Edit.Product_No_Select_For_Edit, 2);GotoPage(Product_Edit);
Then I had code in the PLC which checked for a change in the Value of the tag "Product_No_Select_For_Edit".
If a value was other than 1, then load the tags for the Product (eg Product[n]) into the Editing Array.
I then used another button to save the changes from the Editing Array back to the Product[n] array..
I will get around to documenting this a bit later on...
Each product is part of an array of called Product.
The array uses a UDT, which then has the 50 or so variables underneath it.
So far this seems to work ok.
Let me know if I have not explained this well enough.
Thanks guys for your comments
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
78
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
291
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
299
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
248
