MikeGranby
> PF still has 1 or 2 feature that I added to the RL wish list.
Did we get them all in C3? If not, plese let us know...
I had a nice visit from our rep today with a demo unit. They are going to give me a loaner to try out on my machine before we purchase.
The G403K looks like a very good little HMI. It is very bright and readable from nearly any angle. It boots up (with their demo app) in just a few seconds too.
I think I got my application written, but still have some questions.
The main question I have remaining is how do I control the page being displayed by the G304K from a PLC address?
I have found the scripting section of the manual which explains how to write a script like GoTo(Main) where Main is the name of a page, but is there a way to do that numerically?
Or do I need to write a little switch/case script in the G3 to call the screen by name depending on which value is held by the PLC tag?
Alrighty then,....
Paul
I'll be staying late myself to make sure it gets done.
Paul,
The CBLSK will break out the single port into two, speeding up development time. However, since the PLC end of the SK cable brings out 232 and 485, the pinout probably won't work out for you.
For a connection between the G304K and the PLC's cable, you'd use a CBLGEN01, as well as a CBLADK03.
Have a look at...
http://www.redlion.net/Support/Downloads/DeviceDrivers/G3/AllenBradley.html
and...
http://www.redlion.net/Support/TechNotes/HumanMachineInterface/CBLADK.pdf
We developed the various CBLADK adapters so that we could make use of the numerous cables that we already stock. We intend to streamline the connection in 2010 so that you don't need two parts to make the connection.
The CBLSK will allow you to download to the Kadet without having to disconnect and reconnect the PLC cable, but won't be used in the final application.
Jesse
I hate to ressucitate an old thread, but what ever happenned to streamlining connections for the Kadet model HMIs in 2010? It's 2012 and based on the Red Lion website if you want to plug into a AB PLC that uses DF1 on a DB9 connector you still have to run multiple adapters even though the Kadet HMI has a DB9 serial port. It's just a matter of matching pinouts.
I'm in the same boat as Okie; trying to find a suitable HMI to begin phasing out the PV 300's I've been using. But I don't particularly want to run two different types of communication cable and two adapters to get my HMI and PLC talking.
